HID Fog question
acidrayne280
I'm about to do an HID low beam upgrade and I want to go to HID fogs on down the line. Are there any special considerations such as excessive power draw that I would need to take if I run HIDs in the low beams AND fogs? The vehicle is a 2007 GXP.
AFAIK the current draw won't be any higher with the HID's. Low beam bulb is 55watts and fog is 37watts. Unless the HID's use more then the stated 35watts you should be fine.
