hi all new member 2000 gtp
im new to the site . im haveing some problems with mine it cuts out sometimes when im driveing and when i floor it the sc boost only goes up halfway the check engine light is on it says the maf sensor is bad and the purge control canister solinoid is bad and o2 sensors and a couple other things ive changed the maf sensor and the plugs and wires air filter and i always keep the oil changed i cant afford to just keep swapping out parts any help would be greatly appreatiated thx
welcome, what codes are you getting? You may want to make a post in the tech lounge and someone will be able to help
Welcome to the community. As the others have mentioned, if you post up the codes you are getting and details about the issues you are having you should get lots of help there and perhaps we can get you going in the right direction.
welcome to GPF
