hey im new
monkey man
Have an 04 gp non supercharged. Small modifications, lowered, cat back exhaust, u bend delete, 18 inch wheels, hid and leds everywhere I can put them, but the car just doesnt have enough power, no get up and go. Would like to turbo charge it soon after I upgrade a couple things. Need new heads, valve guides I think are gone or going , hv3 intake insert, cold air intake, throttle body spacer, front power log, v1.0 pcm, im hoping will all help or atleast wont conflict with my wanting of a turbo system. Open for suggestions thanks.
Thanks and I havent been highbeamed since I adjusted them.. And thats what I have been hearing about the valves in these engines, im planning on getting the reconditioned heads with the #90 springs from ZZP.
there is a member on here that does really good head work. his name is Chris Hinson aka orangeL67. the problem you may run into is that the N/A heads dont have the injectors in the same spot as the supercharged heads. if you are going to get head work done I would go to Chris Hinson.
