LePrix
About three months ago I had my 2001 GT stall at idle and rev high and low on its own so I too it to the dealer and they told me I have a bad Mass Airflow Sensor, ok, replaced it $500 bucks right there. About 2 months ago the car just suddenly feel apart, not getting proper reading from the gas pedal and just jerking back and forth and eventually stalling in the middle of a left turn downtown at 11pm. Ok so I tow the POS to the dealer again, they tell me it was a bad MAF...again...replace it under warranty and send me on my way. I stopped to ask "Are you sure the MAF is the only thing wrong in there, maybe something is damaging it?" and the tech told me that since it was only 2 months since the last replacement the best bet is that is was just a defective part.
Now a couple weeks after getting it fixed the second time, my car just doesn't feel the same. It hesitates on the lower gears and the pressure I exert on the gas pedal just doesn't match up to the RPM going up, unless i take my foot off and try again, and then it will rev higher. I have never driven another GP so I do not what what is typical gas pedal resistance and sensitivity but this doesn't feel right.
Also at idle I can sometimes see the RPM needle waver up and down ever so slightly(like it did before it stalled months ago) and if you sit in the car at idle for long enough, you begin to notice a series or pattern of "shudders" that vibrate the car, and again this used to happen right before stall.
What the hell is going on guys?
