HELP???
scotty455
On my way home from work i was driving and all of the sudden the car started shaking real bad and cel started flashing at me. i pulled over and checked my aeroforce gauge and it gave me the following codes: P0171, P0202, P0300. The p0171 i get randomly which is more than likely a vac leak some where i cant find. The p0202 is cylinder 2 circuit malfuntion which im guessing is causing the misfire code. any one else have this code? any ideas if it could be the injector or connector?? Help quickly would be greatly appriciated!!
Check to see if your spark plug wires came in contact with your headers and melted the shielding on the wire. I've had this happen once before. Luckily i had some zip ties and electrical tape to go around the wire and to get it out of the way to get me home.
they didnt i looked all over the wires are all connected the plugs and coils and none are burnt. With my headers the only wire that could possibly come in contact with my headers would be cylinder 4. plugs are fairly new 5,000 miles maybe. If the injector was bad and causing misfires wouldnt i get the p0302 code not the p0300???
