justaV6
So i am in a pinch now. I am moving in less then a month and i have to have my car running before i move. once i move its the only car i have. So basically here is what is goin on. Since i rebuilt my motor i have had problems with it draining my battery, vac leak, coolant leak, exhaust leak. I have fixed the coolant leak and the exhaust leak as well as the vac leak. i thought i fixed the battery drain problem but i it keeps draining while it runs. so today i went out and worked on it and got it started and it idled ok but when i wnt to hit the gas it just wanted to die. when it died i went to restart it and the battery was dead. Also around 4k it has what feels like a misfire. I dont think there is any other vac leaks or anything like that. the gas in there has been in there since i blew my motor so i dont know if its bad gas. I am not sure what else to do. I am at a brick wall and really with out a scanner i have no idea where to begin to look for the issue. I i am just running out of time and i dont know enough about whats going on to get it running.
