help
gottabefast
i have a few problems with my 2000 grand prix gt 3.8 and i was hoping somebody could help me to figure them out. first of all after awhile like ten minutes the temperature idiot light will come on then go off real quick then come back on and repeat, but the temperature gauge will only read 180 degrees. can it really over heat this fast? i live in northern minnesota and it will do this when the weather out side is below freezing. i replaced the water pump, the thermostat, and did a radiator flush there was dirt in the radiator. not a blown head gasket oil looks normal and no white smoke and plugs are normal. could it be a bad sensor? the car has a few bad ones like my gas gauge not working which is anothet problem i need awnsered. and also the car loses power after twenty minutes the idle pully ticks and shakes could that be the problem it loses power? thanks yur help will be greatly appreciated
