Help with water pump replacement.
rastatodd
This is probably just a simple job for most of you members here, but I'm trying to help my daughter out with replacing the water pump on here 2002 Pontiac Grand Prix with a 3100 cid engine. Can some here help by posting a link to a tread that will help me with this matter. Any help lent is greatly appreciated.
Todd
im not sure how the 3100 is in the grand prix in my old olds i had to remove the little guard with the belt routing on it and remove the four little 8mm bolts that hold the pulley on the hub of the pump then theres like 5 bolts holding it on the timing cover the tensioner or idler pulley might be in the way just remove what you need for room for clearance
