Help With My '93
steveprix93
I need some help please... I bought a 1993 Grand Prix with a 3.1. with a major problem. I got it to drive back and forth to work because I heard they were reliable. I've had it for a few months now and then this started happening. If I'm driving down the road it sputters, the tach jumps around alot and it dies. I thought it was the crank sensor so that's where I started. it didn't fix the problem. So I thought I'd try plugs and wires, that didn't help either. I took my coil packs and ign. mod. in to get them tested and they tested fine. My battery was weak, so I replaced my battery and the neg. battery cable because it was frayed. Next was the fuel filter that didn't fix the problem either. I took it to the local GM dealership and they couldn't track down the problem. I'm running out of options at this point. Is it the computer? Is there any way to test it? Any other suggestions? I have been screwing with this for a month and I don't know what to do with it
computer is possible, only good test is a swap test (same with module the testers don't work never have) do you get a check engine light? Can you flash the codes (should get a code 12 first if not the computer is bad)
coil packs and the icm, my '92 did the same thing and new coilpacks and new icm fixed it and hasnt happened since
I took mine to a dealer to check my icm and coils too, they said they were fine, but they were bad, if you can try swapping out each coilpack with a different one if you have one lying around and see if that helps
Will all three coil packs go out at the same time or will one coil pack cause this problem?
Not likely, but I didnt want to take the time to determine which one was bad so I replaced the whole thing..After I looked at the old ones it looked like one of the coils was original (still had the number markings), and the other two had been replaced at some point.
Does it sound more like a computer problem or the coil packs and ignition module? Niether one is cheap so I'd hate to do the wrong one.
I have a set coils and icm here thats known good i changed them cause i thought i had a bad plug i'l let them go for what the local yard does 50 +shipping
Will I have to get it programmed or will I be able to plug it in and that's it? I was told that I would have to tow it to the dealership to get it programmed after a installed the new computer.
Well I replaced the ECM and that didn't solve my problem... I'm going to replace the Ignition mod. and coil packs next. I got on autozones website and where they show the crank sensor isn't where mine was at. I replaced the one on the back of the motor above the transmission but they show it under the harmonic balancer. Are there 2 of them?
