Help with Low beam headlights both sides not working on GP 2008
ibra0078
I have a 2008 GP Base and for some reason both my low beams are not working at all. I changed the fuses and nothing, high beams and the parking lights work fine. I turn the dial to off and it tells me headlights suggested perfect turn it back on and nothing no go. Anything else I should check other than the fuse? The fuse for the low beams are located under the hood. Also want to mentioned I took out a light bulb and it still looks brand new on both sides.
Look for the HDM module in the fuse block. It should be like a 5 pin relay, that is normally the cause for both headlights to go out at the same time.
Yes I believe it's number 35 it seems like, trying to find a shop within Canada so I get it pretty fast. Assuming that is the issue.
Sent from my SGH-I337M using Tapatalk
First try to just pull the relay out and reseat it. My low beams went out all of a sudden while I was driving. I pulled the relay and reseated it and haven't had an issue since.
