Brooks
Attempted cam install, failed to get the crank pulley off. While I was down there I replaced the LIM gasket and put the 1.9's from my shelf back into the genV. I have plog/pem 3'' down pipe, ngk55's gapped .045.
SES came on, powrtunr scan said lean fuel trim and misfire. Cleared it and it hasnt been back since.- As far as driving acceleration, WOT , cruise, MPG is good it just seems to be idle. It would be nice if all I had to do was raise the idle RPM, but instincts say its something more then that.
I have checked/switched plugs
checked/switched wires
removed and inspected injectors
changed fuel filter
changed vac tubing
checked s/c gasket
I have included a video of idle to help troubleshoot. One is just the exhaust because you cant hear it well in the garage.
Your help is always appreciated.
Off Idle
Scan
changed fuel filter
changed vac tubing
checked s/c gasket
Off Idle
Scan
