HELP so the GTP is still leaking after I installed the deflector esp after left turns
ls6velless454
So yeah my car has been leaking ever since I can remember it raining outside, so I read how to fix it (thanks abrasive), and shortly after the car continues to leak. So I removed the piece under the glove compartment and the drain plug on the blower motor to see whenever it leaks. The majority of the time when it leaks is when I take a left corner, so I would assume the seal above the blower motor that connects both the pieces of metal is bad. I can't think of everything else it could be. Any info or input would be welcome, and thank you in advance.
Does anyone know where the rubber boot is located on the firewall I checked club gp and they have a couple other ideas about the leak in the passeneger floorboard
