help please with tensioner pullies
Fox
trying to replace the coupler now. cant get the belts off. does anyone know which ways to turn the wrench on the tensioner pullies below the alternator and the nose cone? tried searching and found nothing. thanks
nevermind. got em both off
edit2: got the alternator off. seems whenever i post a question, i immediately figure out the solution afterward
That's kinda normal. Thing with tensioners is the bolt loosens the opposite way that you push on it to tension/untension the belt. Otherwise the bolt would constantly back out and you couldn't be able to use that bolt.
