Help p2535 ignition switch run/start position circuit high
this is what my scanner says
P2535, Ignition 1 switch circuit high voltage. Dtc sets when the ignition 1 voltage signal is higher than normal for more the 7 seconds.
Check for a poor connection at the PCM and BCM.
Disconnect the ignition 1 relay.
Check the ignition 1 voltage circuit between the PCM and the ignition 1 relay for a short to voltage.
Check the ignition 1 voltage between the BCM and the ignition 1 relay for a sort to voltage.
If all the circuits are ok then suspect either the PCM, BCM or the ignition 1 relay.
good luck
