keenan00gtp
i just bought a 00 gtp. it already has a borla exhaust, i was hopeing for some suggestions to give it a little more thanks
this is my daily driver. im not looking to make it into a race car. i just want a little more. what are some websites that i could look at for these parts? injector suggestions?
Id start with an intake, Cold air inductions is my recommendation but most people have experience on here with a Wizaired.
Second a PCM, you could either get a generic v1.0 or you could have one programed for you after you are "done" modding your car. If the latter then save this step for later.
Ported front manifold aka a plog. If you plan on modding further in the future get headers instead.
Get a larger downpipe, 3" is recommended for our vehicles. [again not needed of you get headers.]
Then you could also get a colder thermostat [180* only $10].
All the above is less then $600 assuming you go with the plog and Dp instead of the headers.
How hard is it to put in the dp and plogs?
When i was on the "plog" hyperlink it had front or front and rear. which should i go with?
A plog is a bolt in part (not too bad) you just have to remove to stock manifold off and bolt the plog in its place. Just becareful about the oil dipstick tube. Most people bend them and have to replace them, just remove it before removing the stock manifold, then put it back in after you install the plog. The dp can be a bolt-in unit or if you get a shorty dp it has to be welded in.
would most dps fit a borla exhaust? there all universal arnt they?
Yes. If you get lets say a 2.5 or 3in dp catted dp, it will bolt up right up to the catback and headers. If it is catless it will bolt-up as well. Just make sure if you go the catless route, that its legal in your state (emissions). Did you have any issues bolting the catback to the cat on your car? If not, then you should'nt have any problems. If you get a shorty, it has to be welded to your cat. It has a flange to bolt up to the headers.
it was easy. im going with the 3" i think and the front plog. will this be enuff to reduce kr if i get a 3.4" pulley also? how small or big should i go?
