With the Felpro LIM gasket kit on the left.....it looks like there's a thermostat gasket and o ring, six bottom fuel injector o rings, the aluminum lower intake manifold gaskets, four side rails, BUT I'm confused where the two orange o rings go and the other two different size black o rings???
With the dorman UIM gasket kit on the right....it looks like there's a plenum gasket with black tube attached to the gasket, 12 o rings (assuming 6 for the bottom fuel injector and 6 for upper fuel injectors), a EGR valve gasket, a thermostat w/ new o ring, the blue o ring looks to go between the throttle body and plenum, BUT unsure where the large orange o ring goes and the two other equal sized black o rings???
Also, on a side question does the tube that is attached to the plenum gasket, does it get installed anywhere inside the plenum??
THanks to anyone and everyone ahead of time!
