HELP!: Car Won't Run
brandonl2000
My dad and I went and bought my 1999 Grand Prix GT today. We drove it two weeks ago and it ran okay [given that the intake gasket is bad]. It had slight trouble cranking the last time. We went to crank it this time and it will not crank for the life of it. It sounds JUST like it has jumped time. It ALMOST hits but it doesn't and it has the slight backfire. We checked every fuse, we checked the fuel pump, we checked the firing of the plugs, everything. Nothing is helping. Is it possible it could have jumped time??
Also, we did not have the keyfob. We had the key only. So is it possible that the anti-theft system could be causing it not to crank? Any info. on how the anti-theft system works will help.
My dad is going to replace the intake gasket as well as check the timing. So is there a diagram/model/instructions for the timing? I want something I can print out so that he does it right.
He just wanted me to check about the anti-theft system and how it works.
And I want something as far as the timing so he can get it right [if that's the issue]. Any other troubleshooting ideas are GREATLY appreciated!
Thanks, Brandon
Timing is basic pull the front cover off and check the chain chains dont jump timing easy keep in mind though
Are there any check engine lights
Bad gas
bad maf
Massive vacuum leak
well all the lights are on in the dash. i thought the light went off when u cranked it.
thats what i told my dad was the gas may be bad. but he said if it ran two weeks ago then no. and how do i check maf? im totally new to a grand prix.
