Help!! C0710
Fishman2580
2005 Grand Prix GXP.
So, i just got done replacing both ABS/Wheel speed sensor harness on both sides on the front and the Vent Valve solenoid canister. Took the car for a drive everthing seemed to be working fine... until i get Service Stability System and Service Traction System. Code is C0710 for the Steering Position Signal. It shows up as history. I can clear it all i want, still comes back. It is also the only code that shows up. Im not sure what it means and how i go about fixing this. Could not find anything on the notorious google. lol Any help would be greatly appreciated. I live in Michigan so i would like to use my traction control.
Might need a steering position relearn. Lots of newer cars require them when getting alignments or replace certain electrical parts.
A fancy scan tool should be able to tell you if there is a procedure to fix the issue. Something like a tech 2 or a solous.
