HELP ASAP!! Port and Polishing supercharger
GP_Kid18
So I am P&P my supercharger before I give it back to my tuner, as I was taking some metal off the two humps (on the left and right if you were to take off the TB an look into the inlet) I took a little too much off the right hump and I made a very small hole, Im not sure as to where I tapped into, I believe it maybe a coolant passage. I have patched the hole with JB weld and tomorrow I am planning on smoothing it out. I am just seeing if there is anything else that I need to do? Will the fix work or do I need a new housing?
From what I have read this should fix the problem, I just would like some input from people that may have anymore knowledge.
Any help is very appreicated!!
Thanks
Flip the charger over and fill the two coolant ports full. Then fill them from the TB side. Smooth things out and don't worry at all.
