Help 2001 Grand Prix water pump removal
prosecho
How do I remove the last water pump bolt behind the crank pulley?Do I have to pull the crank pulley and if so how?
Thanks
Rick
i do not recall u ned to remove the crank pulley to remove only the waterpump. there are only 8 bolts all together tor remove the pump, i think 3 are 13mm and the rest are 10mm IIRC.
turn the powerstearing pulley till the holes line up with the bolts on the powerstearing pump. unbolt them and set it aside now you can get to the last water pump bolt.
learned a couple things here.... have to remove the p/s pump to get to the water pump, and..... after 25 years of living here, i just leanred this state has a town called Friend, weird. first thing i thought was "you've got a friend in friend"
