Brooks
98 Buick Regal GS
Engine:
GenV lim/blower
N*TB
LQ4 MAF
3.4'' dial ur boost
3'' Magnaflow D/P
Ported Manifold/PLOG
9'' Cold Air Kit
1.9 Roller Rockers
autolite 104's
160* T-stat
F body front brakes/rotors
Eibach pro springs
KYB AGX Struts
I started with the 3.8'' and dropped when I saw no KR I dropped to the 3.4''. With the 3.4'' I saw no KR over 1.0, so I stuck with it. I know the first response will be, KR LIKE A MOFO, but I've scanned a few dozen times now and only experienced KR when I was tuning for PE w/maf disconnect and Bin 2 configuration.
I went to 75/80 in Frederick, MD past friday I only ran a 14.6@94mph w/ 2.2 60'. Before my second run, I flashed the PCM back to the stock form (even stock MAF Table) and ran a 14.4@96mph w/ 2.2 60'. I was power braking from 2100rpm with good traction. With the modifications I have and the traction I got that night I expected 13.9 or less @ 100+mph.
As previously stated, I experience no KR and my traction was good, I have no error codes so VAC or exhaust leaks are ruled out and I would feel if the motor were misfiring. Even if I couldn't drive for crap my trap speed should have been higher.
They say stock GTP exhaust is good to 300whp, but Is the stock regal single exit 2.5'' catback killing me?
Does anyone have a gen V bin that I could use as a base if that would work?
I am open to any suggestions, any advice is greatly appreciated.
Thanks in advance,
Engine:
GenV lim/blower
N*TB
LQ4 MAF
3.4'' dial ur boost
3'' Magnaflow D/P
9'' Cold Air Kit
1.9 Roller Rockers
autolite 104's
160* T-stat
Eibach pro springs
KYB AGX Struts
Thanks in advance,
