Hello !
Hom3wrecker
I've had my 05' GTP for a while now and its finally starting to get to that point where I need to start replacing things.
What better place to ask questions and find answers than here?
First one is about suspension. I have a couple subs and an extra battery in the trunk and it squats a little. it has 94k miles on it
I think im gonna have to start replacing springs/struts maybe a front sway bar too?
Just curious on what would be some good parts for this car, most of the stuff I found on here was for the 03 models.
take out the subs, you dont need them. and personally, id only replace the front sway bar if it is cracked or broken. they have a tendency to break on the welds so take a look at that. Or if the rubber bushings on the sway bar are dry rotted, those can easily be replaced if you feel they need to. no sense in replacing the whole sway bar itself if it isnt broke or rusted in half
Super sports chassis...google them and pick up a set of springs they have some meant for audio or just get lowering springs if you choose. The sway you can change if you like get something like a GMPP or Dorman because those are beefier compared to stock.
