Hello Club!
05 Black GT
I just bought a 2005 GP GT and it seems to have a few issues. I have a lot of hopes for this car, but have to get past the small humps. I have a check engine light on. I ran the code and it shot up P0420. I am not yet sure if it is an O2 sensor or a converter. I also have an intermittent ABS and TC light. I am guessing that is probably a wheel speed sensor, because I am not getting any noise from the wheel bearing. I am glad to be here and will get pic up soon!
Chad
Check the wires and connections on the abs wires from your hubs. I was getting an ABS/TRAC light as well for awhile when I hit a bump with my passenger front tire. I noticed later that the wiring harness was no longer clipped into the bracket on the hub assembly. I took the connection apart, reseated it, and clipped it into the bracket, and haven't had the light since.
Welcome, and good luck!
Thank You! I will check on that!
Well, the ABS Light and TC Light was caused by a faulty wheel speed sensor. The check engine light was a bad catalytic converter.......Got the mechanical stuff fixed, now just have to start with some cosmetic improvements! Any Ideas?
