Helllo All! New here. Fun car, guess has somewhat common problem
Chadder0508
Dealing with TC, Service Stability System, service traction system, and airbag deal right now. Trying to find a reasonably priced scanner (under $300) that will reset/calibrate the SAS and go from there. Seems tough to find one that will calibrate a 08 GP GXP. Probably new clock spring but not sure. Really enjoy driving the car though.
Welcome! The SRS light may just be due to a dirty connector or a chaffed wire. Can't recal if the module for those is under the pass. side seat or not but I know it's an issue on other cars when located there. If you plan on working on the airbag system make sure you follow the proper steps to power it down first or you could be in for a surprise, and not a good one.
the traction control/etc issue is likely to be either a wire harness coming from one of the hubs or a hub bearing itself. Likely one of the front ones since these cars aren't easy on front hub bearings.
Get a good transmission cooler on that thing asap.
