Heater fan in 97 GTP issue.
greenfiero1986
My heater fan refuses to come on no matter how much I mess with the controls, the auto light stays off and the man on the screen blinks. I get heat but it does not blow in, although once in a while it will automatically kick on when I don't want it on and I can shut it off and turn it back on a few times then it refuses and the problem happens all over again. Any ideas?
Check the interior temp sensor behind the vent. It's on the right lower side next to the steering column. You will see 3 slots, your sensor is behind it. If it is dirty or has a loose connector it will cause issues with the climate control.
