Jakescoots
You will need a rachet with some long extensions and have the shifter in low
Undo the ruber hoses coming out from under the metal lines and coolant will come out, but not too much
Take the center console out, there will be bolts under it
Now take the top plate off, unscrew it from the shifter and under the radio then pull the whole console backwards and it will come out past the shifter.
Take the ugly carpet pieces near your feet off and undo all the gold srcews for the heater core cover. Removing the cover is the part that gave me the most trouble, I ended up cutting the duct that goes under the carpet and pulling like crazy to get it out (hint: take it out the drivers side)
You will see this after taking out both plastic pieces
Now pull it out by holding on to the top and bottom and reuse the clip at the back
Reverse to put back together
