Hi, I have a problem with the heater on my Grand Prix GT 2003 with dual zone manual temperature control.
The problem is that the air flow is close to nothing when the temp sliders are moved to maximum 'hot'. The air is hot though. When sliders are in 'cold' position - the air flow is nice and strong.
What I've done or checked by now:
- I've flushed and cleaned the cooling system. The heater core output pipe is almost as hot as input one. So I don't think the heater core is clogged. And I had a new one installed about 2 years ago.
- Blower works fine
- I've checked the Air Flop Actuators (both of them). I saw that the metal pin in the middle moves nicely from one max position to another max position (according to the marks on the plastic housing). I did not remove the actuators though and did only a visual inspection.
About 2 years ago my old heater core started leaking coolant and I had it replaced. Also the Dexcool was replaced with the regular coolant.
I think there is something mechanically blocking the airflow through the heater core. I think they could leave something there or did not remove some protection film when installing the new unit.
Do you think that blocking is a plausible reason?
Do you think I can check it without removing the heater core?
Thank you!
- Blower works fine
Thank you!
