Headlights WONT WORK
daltman360
A couple days ago my headlight assembly on my driver side came out while i was on the road. Since then my headlight was trashed so then a bought a brand new pair on ebay and when i was all good and done my low beams wont work but my high beams on the driver side work. Checked the fuse and they all work any ideas please help!!!
Check all your connectors pertaining to the headlights. Make sure that all the pins are seated correctly.
If you have a multimeter, make sure you have a good ground (continuity) and make sure you're getting voltage at each connector.
