Headers for 06
I don't have headers, but those will work with your application. They should connect to the cat. Somebody will chime in with a little better explanation.
they fit fine.
all headers come with a 3 inch down pipe without a cat. being your in CA you'd be best to cut off your stock cat and weld it in the 3 inch down pipe. just make sure you cut the cat open to a 3 inch hole in and out for the 3 inch pipe you will have.
I think I'm going to pull the trigger on these(found out my crossover pipe is leaking because it's rusted out when I thought it was just the gasket).
I just have one more question, will these keep the EGR? I ask because my smog tech doesn't care about modifications, as long as the tailpipe and computer say all is good.
egr hooks up like it should. 100% functional.
another ca member said they dont pop the hood on the 01 up gp's. just odb scan and tail pipe sniffer.
