head light failure
kamikaze275
my 1998 GP SE has a low beam thats out.. my high beams both work fine, but my right low beam wont turn on anymore. i literally just replaced it and it worked for a bit and now i just noticed again that its out. is there anything that could cause the bulb to keep burning out?
Moisture inside the headlight capsule or a loose/shaking headlight capsule could cause short bulb life. Make sure when you replace the bulb that you do not touch any part of the glass.
