aussie
OK, I just bought a 97 GP-GT, 166K Miles.
Was told by owner that the intake manifold gasket was bad, car was rediculously cheap so I bought it.
Here are my symptoms:
Rough Idle
Loss of Coolant
White smoke
High coolant temps
So I bought the UIM & LIM gaskets & started tear down, only to find both of these gaskets have been replaced at some time, obviously not too long back.
I have no coolant in my oil, but have signs of oil in my coolant - the overflow tank had a nice brown slime in it.
The engine runs great over 10MPH, runs like a top.
Its night now, so I have to wait until morning to finish the repair. and hoping for some advise here..
I have plugged the two water ports from the LIM to UIM with quicksteel, modified the water jacket on the drivers side of the LIM (behind the cover thing), I will install the new gaskets in the morning & work my way back to the top...
I have some other issues, Im not sure they are related, but Ill list them just incase:
Fans were not coming on at high temps, I could disconnect the temp sensor then re-connect & they would come on.
Heater was not working at all until I completely flushed all parts of the cooling system - now heat is working - but will not turn off - Vac Leak??
Cooling system was not transferring from/to the overflow tank, it is now, after the flush.
Thanks for reading
Rough Idle
Loss of Coolant
White smoke
High coolant temps
Thanks for reading
