backyard customs
i was coasting up to a red light, the light changed to green before i had to apply my brakes as i tried to accelerate the engine just shut down and here i am 3 months, 1,100 dollars, and alot of stress later and still can't figure out what is going on! i have replaced the fuel pump, fuel filter, t.p.s. sensor, air idle control valve, and a whole new used engine because i spun a crank barring holding at high r.p.m.s. the car will start and run for 5 seconds then stall like it's out of gas, but starts right back up. it will stay running as long as i pump the throtle, but it has to be pumped i can't hold it in one position and keep it running, unless i hold it to the floor. there is no check engine light and my code scanner finds no codes. i can't afford to keep guessing and cause of the cost of the new engine (whitch i swapped myself) i can't afford to take it anywhere and pay to figure out whats going on. somebody PLEASE help, i need this car to run and soon! its a 2000 grand prix GTP with the supercharged 3800.
:th_laugh-pointup:
:th_laugh-pointup:
