idrivejunk
Active member
I need to replace the right rear hub assembly on my 99 GT from a wreck and must do it at my home. The bearing is too loose to drive it to the nearest person I know with better tools / shop.
In order to separate the hub from the knuckle, it has been suggested that I hit it with a hammer in the correct direction or that I air hammer the mounting flange in a rotating manner to break it loose.
There is no access for either method, parking brake is in the way of both approaches. As far as I can tell, hub has to be off before removing park brake for access is an option. Only options I can imagine are:
Install an unwanted bare wheel and sledgehammer on the rim of that. Like thats gonna do anything.
Drive around with no bolts in the hub until it breaks loose, call a wrecker or change hub in the road when it does, and hope for minimal carnage.
Soak with PB Blaster for as many weekends as it takes, and mount a very long pipe on two lug studs then wiggle that and repeat each weekend until I win.
Replace hub / knuckle assembly with salvage assembly. Still don't know how I'd disconnect park brake from the existing, to do so.
Pay to use the frame equipment where I work so I can clamp the car up on that rack and attempt to pull the hub off with hydraulic ram and chain. Other suspension damage likely with this method.
How did you remove yours?
