Harness for coolant temperature sensor
Duffman
hello everyone, so i swapped out my old engine for a fresher one from morad. the day after i took my engine out someone stole it from my driveway, and i never got the whip that connects to the coolant temp sensor to the main harness off the engine. i assume i can just call morad and get one shipped, i was wondering what else that little harness hooked up to though. i know it starts at the 3 prong connector near the front valve cover, and goes to the ect, but where does it run from there? i couldn't see any other open connectors or sensors that were near by the ect
I'm not certain that morad would give you just that portion, you may need to get a whole new harness, which may be the best way to go. Slicing wiring harness wires can sometimes create problems.
i didn't think i needed to do any splicing. i read in another thread that the section i'm missing is detachable like the crank/cam sensor section. but if it involves spicing i will definatly go with a whole new harness
It should be this right?
http://www.jcwhitney.com/engine-coo...jcwx?skuId=498496&TID=froogle&00PoGrSta420094
and from the ect sensor it connects to the big empty connector on my front valve cover with the green, yellow, and black wires? don't mean to be redundant, just want to know what i'm asking for when i call around tomorrow
If you can, post up a picture, that might help narrow it down. Somebody may be able to give you a proper name as well.
