halo projector headlight problem
bcantrell
I have a set of the halo projector headlights for a 97 grand prix and on the drivers side my projection light/regular headlight isn't working. The brights and parking light and turn signal all work just not the "regular headlight". Would changing the bulb help this? Or could the projector be broke?
seeing as the projector is just a fancy reflector and lens if i'm not mistaken, it's most likely the bulb. probably an h1 bulb, but you'll have to double check.
Agreed that its most likely the bulbs. Afaik they go for 12$ a pair on eBay so you can't really expect them to last too long. Also the wiring harness adaptor they come with is dodgy as all hell, so you might want to check the wiring out of it. Good luck
yeah i've noticed that. another question though. is the H1 bulb inside the projection area or is it the same bulb for my regular headlights and my brights?
