gtp
mtz956
my gtp has alot of bivration when i step on it as soon as the supercharger kicks in the bivration starts:confused::confused:
does a k&n coldair intake really make a difference over stock on a 2001 Gtp I have a few mods 3.4 pully magnaflows coldplugs 180-T stat & zzp pcm coming soon
Re: gtp brivationn
o ya buddy that is one of the first mod u should do.. u will feel da difference...
if it does it when you accelerate heavy it could be axles but it could also be numerous other things... Have more details on when this started?
WAIT..... you have a 3.4 pulley, without an intake? Magnaflow mufflers, but probably no u-bend delete. so technically all you have to run a 3.4 is colder plugs and a 180 T-stat? I sure hope you don't go WOT.....
yea its probably knockin like a b1tch... ever smashed a spark plug? and its vibration... not bivration...
and maybe make ur own thread... or even READ and SEARCH instead of asking questions that have been answered 4756639567934673 times. :th_shakinghead2: and to the OP u have a 3 in downpipe by chance?
vibration on accel is usually a cv/axle issue
if it only picks up at higher speeds have your tires checked for balance and have your axles checked as well
