Gtp turns off here and there!!
GTPinSF
NEW GUY HERE WITH A QUESTION!! I have a 00 gtp with 110k it runs great havent had any issues until recently.. i can drive my car fine all day but then will shut off out of nowhere. it turns right back on and drives fine but will do it again a few hours later.. and info will help
no i never noticed that!! but i did notice that the boost doest always work not sure if its suppose to always move it only does ocasionally.. i onlyh ad the car for about 2 months so im still tryna figure it out
Would a big enough Vac Leak casue a stall? Although I did have a CPS go bad in my Bonnie but I would also notice after a stall it wouldnt crank over al the time, it sometimes needed to sit for a while.
I had my CPS go out on my other GP...I took it in. They said they had some trouble pulling the harmonic balancer and had to modify their puller. Im glad I didnt try and do it. But the tell tale sign I had was the Tach. I knew once it dropped to zero while driving, it was about to shut down.
look under ur supercharger snout... theres a rubber T fitting vac line that goes on the intake manifold. that could be ur culprit.. they dry rot and come all the way off creating a huge vac leak that can make u stall from time to time.
it may not be a vacuum leak, hes only had the car for a couple months, hes probably not used to the s/c. the dic boost gauge-ish thing doesnt really show boost untill ~3k rpm.
granted a vac leak will cause it to sltall out, and its an easy place to start, so id still say check.
