GTP Swap
SmurfyGTP
I wish to swap motors with an 07 GTP I found in a junkyard. Are the Motor mounts on an 07 GTP the same as a 97 GTP, and are they located in the same spots?
07 will have an aluminum oil pan and a different mount. They are in the same place. However they are different. I like the 07 design better. You will also need a TB adapter if you are buying a complete engine.
