GTP Problems on my 97
chevyman
My car runs fine butt when i check the oil or take off the oil cap it seems to be pulling in air and makes my motor squeel a bit if i dont keep the dipp stick out to stop the air from sucking into the motor, I have replace the pcv dint help any idea Thanks
Well something might be blocking the pcv or something. So you are saying your engine runs better with the oil cap off? Then you should get a valve cover breather.
Sorry about posting in the wrong area still learning the site. I replaced the pcv and o ring seems to be fine Any one know where it could possibly be pluged at in the system? Thanks for the Help im Stumped
It runs the same for the most part makes a bit of a noise of sorts in the motor when the preasure builds up i open the cap or pull the dipstick out and it suck air in and then stops Crazy!
