Gtp Lim and supercharger tourqe specs and sequence
pontiacGTP123
I need a pic or something for the torque specs and sequence for the lim and supercharger for my 99 gtp. I'm replacing the gaskets.
LIM is 11ft lbs, S/C is 17ft lbs
Can't find a pic for the S/C, but start with the center 4 in an X pattern, then do the outers. Make sure to double check each bolt, because as you tighten more, the first ones will be loose.
Also, make sure the S/C spins by hand easily after torquing it, if not, loosen the bolts and retry.
Thanks I got it done. Not to bad of a job. Just got to replace some broken vacuum lines. Damn things was brittle as hell. Put new aluminum coolant elbows on, and changed the s/c oil while I was at it.
Vacuum line is like $12 from the dealer or just make your own.. Personally I went the dealer route for as cheap as they are.
