98RedunicornGtp
I have 98 Gtp having misfire in cylinder 3 and 4 only at idle . On the highway I could be doing 75 and try and give it gas slowly and it sounds like it's bogging down till supercharger makes boost . My abs light and tsc off light stays on and recent had swap back to stock pcm after a ecu malfunction code which made my car shift really hard and delayed . Changed plugs and coil paks wires check injectors . And tryed to swap things around to chase the misfire but no movement. My interceptor gauge reads 14 misses in 4 in the cycle scan and 2 in cylinder 3 . I checked plugs the had orange tips normalburn idk . I know I need new pcm but unsure of my setup . 3.5 pulley cold air intake stock injectors and slp exhaust . Any tips ?
