Greetings all,
Couple of weeks ago, went to get in the car (02 GTP 205K) and when I opened the door, got a real fast dinging alarm -no key in ignition - and the daytime headlights and dash lights would not come on after starting. Got the headlights on by turning the main switch on. No dash lights though. After a few minutes, all came back on as normal. It did not happen again.
I've had this issue before and solved it by changing the main ignition switch harness which I did. (the car is on its 5th one.)
After about a week, it happened again - once - and not since.
I've gotten bad replacement harnesses in the past that haven't lasted a week but before I change it again, are there any other possibilities worth checking? Not sure of the proper terminology but is there anything in the actual key tumbler that could cause this?
Thanks in advance.
Thanks in advance.
