The Mad Hatter
Hello all! Long time lurker, first time poster. I've been scanning all the forums looking for someone who's had this issue but i've yet to find anyone, so i'm asking for help. My 2007 base Grand Prix has developed and issue with the power to car "blipping" for just a split second, but it's enough to cut the engine off while driving. It will start right back up immediately, but here's the weird part, it does this blip about every 60 seconds now. Here is what i have attempted so far to fix:
-Replaced the crank position sensor with a brand new one
-Replaced suspect battery terminal that i'd had trouble with before
-Switched ignition relay with horn relay (known working relay)
-Jiggled ground cables (this did not cause a blip)
None of these fix attempts rectified the issue. I have no codes stored, and no dash lights (other than the tire pressue sensor, hate those things). I'm stumped so i'm out here looking for help. I'm not great with electrical so any help is greatly appreciated but bear with me as i figure it out. Thank you in advance for any help, this is my daily driver and it's stuck in my driveway, i can't trust it. I will try to add a video of it blipping when i get home tonight but I don't know how much that will help, all i can hear is some relays clicking and the fuel pump priming. It does this with the key on ACC or running, but obviously if it does it while running the engine shuts off. It does not do it with the key off. Thanks again for any help!
