Grand Prix GTP Parking lights not working???
mick777wauchope
I have a 2000 grand prix gtp
My turn signals would both work, but only one of the parking lights work (same bulb). After replacing the bulb a couple of times, and replacing the cluster of wires that the headlight assembly goes to, it still doesn't work. Any help please???
Have you checked for voltage at that bulb connector? Sounds like you may have a bad wire in the harness that feeds it.
Im gonna question the connector that the bulb sits in. The corner light housings, along with the tail lights are notorious for leaks. My tail light connectors were corroded as hell and the tails would work when they felt like it. I replaced those and sealed my tails and have never had another problem.
Yep. Heck, my drivers corner has so much water in it right now I could use it as a fish bowl, lol... Still wondering how the bulb hasn't burnt out yet. Need to replace that one of these days w/ some clear corners...
I replaced the wire harness that feeds to all of the bulbs in the headlight unit, as well as the bulb. Still doesn't work. Without tearing into the electrical system inside of my car, are there any alternate solutions?
