GP parts fit Bonneville ?
Ok thanks. Will the motor and transmission bolt right in if its out of my 01 GP or is the cradle different. I hope cradle is the right word lol
Maybe... First off... Engine is no worry at all. It'll work, just change the rear exhaust manifold if it still has stockers.
Transmission. You need to look at the one in your GP. If it looks like this in the back driverside, then it won't work
Bonneville has a rear bracket that requires more structure. To put your trans in a Bonneville, it needs to look like this.
With basic tools you could swap the parts from your trans into a different casing with the structure if you had a case that had bad guts in it. You would need only the channel plate gaskets. ~$20
