Got ****ed in the ass by my Dad
timothylockhart
Ok so first of all i bought a 2001 grand prix se 3.1L for $2150
I thought the kid was an alright guy until I noticed one of the windows were held up by a 2x4... he obviously knew that was wrong and didnt tell me so now I wonder what else is wrong with it and I assume the worst
the speedometer reads 20mph off
there is oil in the coolant... I dont know if this is residue from a fixed head gasket or if the LIM is eaten away and the oil is leaking into coolant because there is no coolant in the oil.... or if i have a cracked head or block...
Im planning on doing a flush tomorrow
Re: Got ****ed around on a craigslist deal please help
why buy a car with a 3100 in it? you broke rule one.
these engines have head and lim gasket failure all the time. so plan on doing that asap.
the window regulator is the least of your problems right now.
Because my dad strong armed me into buying it because he drove 30 minutes to see it... I had no say with my money sigh
Sent from my SM-G900P using Tapatalk
go tell dad he owes you your money back then lol
your gonna have to get your hands dirty on this one.
Only 2k not that bad and it runs and drives... Is it possible to replace the gaskets at home without any major equipment? How much do gaskets run? How do I know if it's not a cracked block or such and is indeed gaskets
if its got coolant in the oil do not drive it. or run it. you;ll spind a bearing and need a whole engine.
a basic tool set will get the job done. and a torque wrench.
gaskets and head bolts and fluids around 200 i'd think all and all.
shop around for the best prices on line for the gaskets. id stick with felpro gasket if you can. advance auto on line, find a discount code for more off, ebay, amazon, rock auto and so on. shop them all find your best prices.
Your saying a blown head gasket can't put oil into your coolant???
It may just be dex sludge it did have green in it and I know the cars come with dex
it pretty much physically impossible to get oil in the coolant.
unless you have a oil cooler in your rad, and a doubt you have one of them.
"Only" 2k? I paid 2k for a running, driving, modded AWD Talon in great shape. You screwed yourself by not doing your homework.
So you think it's sludge then? And a flush should set me straight
lets hope so. you may want to add some rad flush to it to clean it up better then just a flush.
is it running hot? leaking coolant? or coolant missing and no leaks? or the check engine light on?
No check engine light... Small power steering leak doesn't run hot that I've noticed hottest I seen was 210 after 30 minutes of driving and on a hot day
There's no way to disable the check engine lights is there? Have an odb2 sensor that won't communicate with ecu on this car but will on another... It is a cheapie from Amazon so it might just be the sensor not liking my car
check the cig lighter fuse, the obd2 port runs off that fuse. inside fuse box is where to look.
It receives power the sensor does just can't talk to ecu
