GoGroove Flexsmart Fm Transmitter?
rodguezsciii
Comp G with 6 disc, Monsoon
I've read good reviews on the Flexsmart X2, so so reviews on the newer Flexsmart X3....never used a FM Transmitter, so not sure what to compare it to....
Anyone with any experience with this specific device, or other FM Transmitters....
a tape deck thing works better, the fm modulators really do sucks balls in the end.
you can tap the cd changer input with a aux port. sound will be much better.
That was my first impression after searching for them....but this specific GoGroove Flexsmart X2 has good reviews, and added bluetooth capabilities....besides I plan on getting an aftermarket radio pretty soon, so if it works like advertised it'll hold me over until that happens, and afterwards the wife can use it....
all i know is i used one for my XM years ago. that will never happen again. big waste of money, they are not as loud, nor do they sound as good as a hard wired set up. that dead radio station will tune in and block its signal sometimes. aka, a pita. i took my antenna off my last truck, then clipped the modulator wire to the threaded nub, that was the best reception i could get.
like i said, the tape deck adapter works way better. the aux input works the best. if you can install it.
