GM Delphi-Packard Connector Part Numbers
Toasty
This list will contain known part numbers for various connectors found within GM vehicles, more specifically the 97-current Grand Prix
Connector information for 97-03 HUD switch:
Matches in car harness plug:
2064766 Metri-Pack 150 female 8 way connector
12064971 Metri-Pack 150 female terminal
12064768 Metri-Pack 150 female 8 way Terminal Lock
Mating connector:
12064767 Metri-Pack 150 male 8 way connector
12059894 Metri-Pack 150 male terminal
12045690 Metri-Pack 150 male 8 way Terminal Lock
Connector information for the 'power drop' harness behind the glovebox- sourced from mouser.com, minius a few 6 inch pieces of wiring (presuming you have some extra wire somewheres) , the total with shipping is under $7 dollars. --that's a savings of over $10 vs the official vendor that sells these.
12129489 -- Metri-Pack 280 female 3 way connector
12129424 -- Metri-Pack 280 female terminal
12129491 -- Metri-Pack 280 3 way terminal lock
Since Ive been working on re-wiring my engine bay, Ive had to find out what connectors I could get my hands on and which ones I was going to have to find other solutions for. Ive compiled all the info and thought I would post up here so that its available for anyone that needs it.
Connector: Mass Air Flow Sensor
Mouser Part Number: 829-12059595
Delphi Part number: 12059595
Manufacturer Part Number: 12059595
Assembly: Yes
Connector Seal Part Number: 12052842
Terminal/Pin Part Number: 12048074
Connector: Throttle Position Sensor
Mouser Part Number: 829-12110293
Delphi Part Number: 12110293
Manufacturer Part Number: 12110293
Assembly: Yes
Connector: Camshaft Position Sensor
Assembly: Yes
Connector: Crankshaft Position Sensor
Mouser Part Number: 829-12162834
Delphi Part Number: 12162834
Manufacture Part Number: 12162834
Assembly: Yes
Connector: Idle Air Control Valve
Mouser Part Number: 829-12162190
Delphi Part Number: 12162190
Manufacturer Part Number: 12162190
Assembly: Yes
*Note: Mouser minimum quantity order = 660
Alternative Source: None At This Time
Connector: Heated Oxygen Sensor, HO2S1
Mouser Part Number: 829-12160482
Delphi Part Number: 12160482
Manufacturer Part Number: 12160482
Assembly: Yes
Connector: Heated Oxygen Sensor, HO2S2
Mouser Part Number: 829-12160825
Delphi Part Number: 12160825
Manufacturer Part Number: 12160825
Assembly: No
Connector: Exhaust Gas Recirculation Valve
Mouser Part Number: 829-12186056
Delphi Part Number: 12186056
Manufacturer Part Number: 12186056
Assembly: Yes
*Note: Mouser minimum part order = 750
Alternative source: None At This Time
Connector: Evaporative Emission Canister Purge Solenoid
Mouser Part Number: 829-12052643
Delphi Part Number: 12052643
Manufacturer Part Number: 12052643
Assembly: No
Connector Seal: 12103067
Terminal/Pins: 12048074
Connector: Windshield Washer Fluid Pump
Mouser Part Number: 829-12052641
Delphi Part Number: 12052641
Manufacturer Part Number: 12052641
Assembly: Unknown
Connector: Windshield Washer Fluid Level
Mouser Part Number: 829-12162795
Delphi Part Number: 12162795
Manufacturer Part Number: 12162795
Assembly: Yes
Connector: Vehicle Speed Sensor
Mouser Part Number: 829-15336004
Delphi Part Number: 15336004
Manufacturer Part Number: 15336004
Assembly: Yes
Connector: Intake Air Temperature Sensor
Mouser Part Number: 829-12162199
Delphi Part Number: 12162199
Manufacturer Part Number: 12162199
*Note: Mouser Minimum Order Quantity = 750
Connector: Cruise Control Module
Mouser Part Number: 829-12065425
Delphi Part Number: 12065425
Manufacturer Part Number: 12065425
Assembly: Yes
