Glove department
94grandprix
How do I remove my glove department in my 98 gtp, I need to remove it to get to my hvac vacuum actuator,that's where the purple vac line is going?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
take the foot cover off, then there a few screws in the hinge for the glove box. open the latch and have to push the sides in so the clips pass the sides. and thats it.
Ok I'm thinking about going to do it right quick and the door and actual box comes out in one wack?
yup. all one part. its a easy removal. the tree clips that hold the cover up will be more work to get off in the end.
yes the foot cover with the light in it, it needs to come off so you can get to the bolts that hold the glove box hinge in.
my regal has 3 of them tree clips holding it up iirc on the pass side.
Gp has 2 I think and what do you mean push in so the clips pass the sides
they look like this, theres a tool to get them out, but if you dont have it you can grab them with needle nose pliers wiggle it down one side and then pull it out or pry it out.
oh miss read this.
when you open the glove box it only comes out so far because theres two tabs, one on each side of the box that hold it in/up.
now that i think about it, once the hinge is free open it and tilt it diagonally the tabs should clear and the glove box will come out.
its been a while since i had mine out.
