    TIPS:
Gen v sold
Status
Not open for further replies.
Impala131
Includes the following items:
Photos
Gen V S/C with ~60,000 miles (SOLD)
Looks great, was told it came from totaled 2005 GTP. Unit has not been used since pulled.
Needle bearing grease refreshed, brand new LaRossi coupler, sealed with permatex anaerobic sealant. Unit ships dry but 2 bottles of new S/C oil are included (in case you want to take the S/C apart again for whatever reason).
Butterfly valve for boost bypass, some of inlet area, rotor housing area have been cleaned (mostly to inspect for any abnormal wear, unit looks great).
Rotor lobes have not been touched, and the black coating is in great shape.
Torx bolts were removed and regular bolts have been installed in their place. Unit is not painted.
BBV, BBV solenoid, top vacuum tree included. EVAP/EVAP blockoff not included.
Gen 3 LIM with inlet machined to Gen V size
Gen V S/C gasket
The metal/rubber variety, never installed, just used as template for cutting LIM.
Northstar Throttle Body (no adapter)
IAC and TPS included with connectors and some wiring left on connectors
85mm MAF sensor from 2001 Cadillac Northstar Engine
Connector with some with some wiring left on connector
New PCV Valve
Asking $400 for all of the above, plus actual shipping costs and paypal fees if you choose not to send as friends/family.
Ships from Manchester, TN
Status
